Almost any hardware changes we requested is in the new version's features:
I created this thread to discuss about the new product. It's ready to purchase from "sdrplay.com"
- Here are the main additional features of the RSP2:
- 10 built in front-end pre-selection filters, with substantially enhanced selectivity
- Frequency coverage extended down to 1 KHz
- Software selectable variable gain Low Noise Preamplifier
- 2 x SMA Software Selectable 50Ω RF ports (1.5 MHz – 2 GHz)
- 1 x High Impedance RF port (1 kHz – 30 MHz)
- Built in software selectable MW /FM notch filters
- Highly stable 0.5PPM TCXO trimmable to 0.01PPM
- 24MHz Reference clock input / output connections
- 4.7V Bias-T option (on one of the software selectable antenna inputs)
- RF screening within a strong plastic case for the standard RSP2
- A Rugged metal box version – the ‘RSP2pro’
Right now I've got a question: When will the RSP2pro (metal box version) will become available and is its price determined yet?
Can you give more information about its technical characteristics versus the plastics box version? (have you tested it to see how much it affects external noise?)
Best regards and thanks again
