Seeing spectrum of UHF (HDTV) Broadcast Band
Bill787
Post by Bill787 » Sat Sep 09, 2017 8:41 pm
Hi everyone. My first post.
If I were to use SDRplay to view the U.S. HDTV broadcast band (470-806 MHz), could I see spectra of all the HDTV channels coming down from my rooftop antenna? Could I see the entire spectrum at once? Maybe not, as I see the SDRplay description says "Up to 10 MHz visible bandwidth.".
Thanks in advance for any clarification . . . SDR seems like an amazing new world to me :)
Re: Seeing spectrum of UHF (HDTV) Broadcast Band
Post by g1hbe » Sun Sep 10, 2017 8:48 am
As you suspect, you could see only 10 MHz at a time. There's not a lot to see with digital TV, just 'blocks' of what looks like noise. Looking at analogue TV signals used to be quite interesting as you could pick out the main video signal, the chroma subcarrier and the sound channel.
Bill787
Post by Bill787 » Sun Sep 10, 2017 3:31 pm
Hi, Andy. Thanks for the confirmation of the 10MHz viewable spectrum limitation on SDRplay. Not a problem of course, as I can still explore the entire band as I rotate a rooftop antenna. I live close to St. Louis in America, and can remember those very rare occasions when analog UHF signals came skipping in from hundreds of miles away. Not like the chaos that would happen to the VHF band when the skip was up, but here in the U.S. at the time of digital transition the vast majority of TV stations were moved up to UHF from our previous VHF television band of 54-216 MHz. Our analog TV was turned off in October 2012.
I miss the wonderful quirky days of Analog. Except of course every time I turn on the TV and see the glorious quality of broadcasting in our Digital age :D
P.S. - For those on this side of the pond, there is a great web site about U.S.TV allocations:
http://www.fcc.gov/media/television/tv-query
dlritter
Post by dlritter » Mon Sep 11, 2017 2:33 am
I don't believe anyone has created a Spectrum Analysis app for the Mirics chip set..
I use Spektrum and touchstone with the RTL dongle and Spectrum Spy with the Airspy...
the actual bandwidth of the device is of no concern if it can be stepped/scanned fast enough..
F1BJB
Post by F1BJB » Mon Sep 11, 2017 7:00 pm
g1hbe wrote: There's not a lot to see with digital TV, just 'blocks' of what looks like noise.
That is not true :)
If the top of the noise is not flat it indicates either a badly oriented aerial with echoes or SFN or MFN interference.
Here you see the difference between channel 22 correctly received and the 23 where two SFN TX are interfering
There was a sudden frequency drift between the 2 transmitters as can be seen in the waterfall.
You can also see the +166KHz offset of french TV transmitters.
The snake like display in the waterfall is typical of interference from 2 TX .
For echoes the lines are straight.
ab1jx
Post by ab1jx » Thu Sep 28, 2017 4:39 am
rtl_power doesn't have a limitation like 10 MHz, but it doesn't exactly do it in real time either, it retunes.
This is output from Heatmap, a little Python script that plots from the csv output. There are also several forks of it but it's part of the rtl-sdr suite.
If you have any serious funding, take a look at what Pentek offers, but as somebody put it you could buy a whole ham shack for what one of their boards costs. They apparently sell to industry, military, NASA. Take a look at http://www.pentek.com/selectguide/IO_SelectGuide.cfm But doing the number crunching with FPGAs or ASICs makes sense, it just isn't cheap. A/D sample freqs in the GHZ? Jeez. They don't list any prices, you contact them for a quote.
