RSPDuo and Dump1090 - help needed
I2SVA
Post by I2SVA » Tue Oct 09, 2018 4:43 pm
Hi all,
can anyone help me? I am trying to set up DUMP1090 with RSPduo with/without SDRuno but no success at all. My O/S is Windows 10.
I installed ADS-B (DUMP1090) V1.3 and the required API from SDRplay download page.
I have tried both with API/HW driver V3.01 and with API/HW driver V2.13.
Major issue:
- DUMP1090 seems not to start (the cmd windows opens for a moment and then close); this happens both by launching start_dump109 or start8i
- entering the command console, moving to the proper path and then launching directly sdrplay_dump1090 from the cmd console, the program start/stop and returns the following message:
Tue Oct 9 18:28:44 2018 dump1090-mutability dump1090_mutability_sdrplay starting up.
Using sample converter: UC8, integer/table path
No supported RTLSDR devices found.
This happens both when SDRuno is running Dual ADS-B and when SDRuno is closed
Therefore it seems that DUMP1090 does not see RSPduo, but I have no idea why and how to troubleshoot/solve the issue
On the other end SDR RSPduo is working well with SDRuno, therefore no doubts that it is connected to the pc and properly functioning.
thanks for any recommendations!
73
Alessandro, i2sva
Roger
Re: RSPDuo and Dump1090 - help needed
Post by Roger » Tue Oct 09, 2018 7:28 pm
I2SVA wrote:Hi all,
Alessandro,
It appears that you are not using the version of DUMP1090 that works with the RSP duo. You can download the RSPduo version on the SDRplay site in the downloads section.
Roger
I2SVA
Post by I2SVA » Wed Oct 10, 2018 7:27 pm
Hi Roger,
thanks for spotting the issue on dump1090 version, my fault!
I have now removed ADS-B V1.3 and installed 1.41 but nothing has changed. Launching sdrplay_dump1090 the console start and suddenly close. Entering the console from the Command line I get the same error message as before "No supported RTLSDR devices found"...
Thanks for helping.
Alessandro
Post by sdrplay » Wed Oct 10, 2018 11:36 pm
Look at the start .cmd files for the correct command line options.
Or add --h to see a list of options.
--dev-sdrplay is required for RSP (default is RTL)
I2SVA
Post by I2SVA » Fri Oct 12, 2018 12:45 pm
Hi Support,
**the start8i batch file has the following syntax:
@echo off
title CTRL-C to EXIT - v1.41 High Perf Interactive dump1090
.\DisableClose.exe
.\sdrplay_dump1090.exe --dev-sdrplay --interactive --net --oversample
pause
**When I run start8i from the cmd line I get the following:
Hex Mode Sqwk Flight Alt Spd Hdg Lat Long RSSI Msgs Ti|tarting up.
Couldn't find a RSP
sdrplay_api_ReleaseDevice error: sdrplay_api_InvalidParam
Fri Oct 12 14:41:40 2018 Normal exit.
Premere un tasto per continuare . . .
**When I run start8i from windows I get:
Fri Oct 12 14:43:19 2018 dump1090-mutability dump1090_mutability_sdrplay starting up.
Using sample converter: SC16, integer path
Couldn't find a RSP
Fri Oct 12 14:43:19 2018 Normal exit.
Thanks for supporting,
Alessandro i2sva
I2SVA
Post by I2SVA » Fri Oct 12, 2018 1:24 pm
Hi Support,
strange enough, the SDRplay started after I run it from cmd line :
sdrplay_dump1090 --dev-sdrplay --interactive --net --oversample
Now it starts well every time also from windows by double clicking start8i, therefore the issue seems solved.
Alessandro i2sva
