As you may have seen, version 1.33 of SDRuno has now been released which goes some way to including the features promised in the previous roadmap update.  The remaining features along with other priority requests are now planned for the next releases as shown below:
1.4
  • Plugin API
  • Automatic LO adjustment
  • Start SDRuno with just wav file with no RSP
  • VFO Lock
  • Fix SWFM > 50% Volume audio distortion
  • Fix Known Issues
1.41
  • Improved ini file support (backup/restore)
  • Generic Scheduling Function
  • Includes upgraded recording system
  • Recording of selected signal only (either I/Q or audio) to WAV file format
  • Pause Record on squelch
  • Improved recording scheduler (multiple entries)
  • Ability to create and recall complete receiver profiles
  • More levels of zoom for close in signal identification (SP2)
  • Save VFO for each VRX
1.42
  • Remote operation
  • New TCP Server (cross-platform)
  • SDRuno client
  • Memory Panel updates (if blank use current value)
  • RF Gain
  • IF Gain/AGC enable
  • Scanner Threshold
  • Scanner updates
  • Lockouts in a separate file
  • Statistics logging
  • Use memory panel threshold
1.43
  • DX Cluster Plugin
  • SP1 Band identifier
  • Start-up tips
  • Custom controls
  • SP2 Filter bandwidth
  • Up to max available SP2 bandwidth for RX mode
  • Band buttons
  • Variable band centre
  • Bandwidth from a selectable list
2.0
  • Cross Platform (Windows, MacOS, Linux) x86
  • Add Hamlib support for non-Windows platforms
  • GUI update – ability to lock panels together
