If you’re unsure which RSP is right for you then watch the video below.
The RSP1B is the best low-cost choice for anyone wanting a well-supported general coverage receiver which in most circumstances performs as well as a more conventional communications radio.
The RSPdx has the advantage of three software selectable antenna ports and a special “HDR” mode for better dynamic range below 2MHz.
The RSPdx-R2 is a redesign of the RSPdx to address component supply issues and has resulted in additional performance enhancements below 2MHz (e.g. the noise level below 1MHz)
The lower cost RSPdx is still a good choice if your main interest is in frequencies of 2MHz and above, as long as component supplies allow.
The RSPduo remains unique with its Dual Tuner and Diversity Tuning capability.
For a stand-alone networked radio, check out the new nRSP-ST: https://www.sdrplay.com/nrspst/
Whichever RSP you choose you will be supported by an enthusiastic technical team ready to help, especially if you are a newcomer to SDRs.
For links to detailed information (datasheets etc.), please visit our products page
If you have further questions about the suitability of an RSP for a particular application, you can contact us with your questions by clicking here
